Program exceeds machine maximum X and Y Axis
28 Jan 2025 21:09 #320038 by waldo
Okay, I put created a new project in sheet cam and put the run post processing and went over into CommandCNC - Star Lab and when I hit Run From Line it says Program exceeds machine maximum on axis Y and axis X. please help!!
29 Jan 2025 03:37 #320064 by Aciera
29 Jan 2025 06:36 #320076 by waldo
So i went to my fixture offsets and it say G54|X-70.7491|Y-(-3.5438|Z 0.0000| Offset name G54. the rest of the offset names have 0
29 Jan 2025 06:52 #320081 by Aciera
Impossible to diagnose with the information given. A screenshot of the preview might shed some light on the matter.
29 Jan 2025 16:54 #320122 by waldo
Here are the pictures
  • Moderator
  • Moderator
29 Jan 2025 17:19 #320123 by tommylight
Replied by tommylight on topic Program exceeds machine maximum X and Y Axis
CandCNC ?
29 Jan 2025 18:45 #320127 by waldo
  • Moderator
  • Moderator
29 Jan 2025 19:20 #320128 by tommylight
Just asking, no help on their forums or no forums at all?
On the first picture, it shows up at the offsets as 70 on X, while lower it shows -70?
On the third and fourth picture, the starting points are OK for both X and Y, but end points are over the limits on both X and Y, meaning even if you move the offsets for X it will still not fit on Y as there are no offsets on Y.
What is the table size?
Is the Plasma (you should have mentioned it is a plasma) set in metric or imperial?
What CAM are you using?
29 Jan 2025 20:02 #320130 by waldo
In my fixture offsets it shows 70 for X and on the lower half it shows -70 for Y. I believe the table is a 8 x 12, Star Labs. How would i check if it is metric or imperial? I also use SheetCam TNG for my CAM
03 Feb 2025 13:40 - 03 Feb 2025 13:42 #320525 by Aciera
I just had this problem where it says Program exceeds machine maximum X and Y Axis. I cannot figure out why it is saying this i’ve had the CNC PLASMA CUTTER (5x10) for about a month and never encountered a problem like this. I have a few pictures! If someone can help please let me know, thanks!!
Moved here from your other thread which I locked.
forum.linuxcnc.org/38-general-linuxcnc-q...-x-and-y-axis#320519
Please continue here.
Last edit: 03 Feb 2025 13:42 by Aciera.
Time to create page: 0.376 seconds
