- LinuxCNC
- General LinuxCNC Questions
- Source code to send instructions to the joints through the parallel port
- noqui
29 Jan 2025 23:36 #320125
by noqui
Source code to send instructions to the joints through the parallel port was created by noqui
Hi, where can i find the source code to send the instructions to the joints through the parallel port ?
Thanks a lot.
Thanks a lot.
31 Jan 2025 10:58 - 31 Jan 2025 10:59 #320225
Replied by andypugh on topic Source code to send instructions to the joints through the parallel port
The data path you describe includes almost all of LinuxCNC.
Starting at the end, have a look in src/hal/drivers/hal_parport.c
Or if you want to send binary data, possibly src/hal/drivers/pluto_*
Last edit: 31 Jan 2025 10:59 by andypugh.
The following user(s) said Thank You: noqui
- noqui
01 Feb 2025 03:25 #320277
by noqui
Replied by noqui on topic Source code to send instructions to the joints through the parallel port
Thanks a lot andypugh!! Great Help!!
I am trying to instead of manually type the instructions (Commands + units to move each one of the axis) or read them from a file, to automatically receive that data from an other application written in C. So i should add in the CNC panel a button to select or deselect "automatic data transmission (Commands + units) towards the axis, that should switch from receiving the data through the textbox "Enter the MDI Commands" to a kind of transmission connection that automatically would receive the data. It would be of great help to find out, where is the code for the function of the "Go" button.
Thanks a lot for the help.
- Thank you received: 426
01 Feb 2025 05:09 #320283
Replied by Cant do this anymore bye all on topic Source code to send instructions to the joints through the parallel port
This maybe of help
linuxcnc.org/docs/html/man/man1/linuxcncrsh.1.html
This one may have you going through the docs
linuxcnc.org/docs/html/man/man1/linuxcncsvr.1.html
- noqui
01 Feb 2025 14:39 #320325
by noqui
Thanks a lot, you are very valuable here. The best for you. I use my CNC also as a laser graver, and with the 6 motor steppers working I can make a arm robot of 6 degrees, that means 6 joints what it can in the entire space approaching any location in the space where is the object from any angle with the tool. It would be wonderful if there would be in the stepConf an option to select 6 labels XYZABC or XZYUVW. I don´t know why in the AXIS appears ABC, and where you configure the pins in UVW (step V, Dir V, etc). How do i should compile the source code copied from the GIT to my repository if I make a change (what compiler should i use) ? Many Thanks
- LinuxCNC
