How to Implement T1M6 and T2M6 for Dual Z-Axis in LinuxCNC
1 year 9 months ago - 1 year 9 months ago #320216 by pd_2832
I'm working on a multihead CNC machine with a dual Z-axis configuration. My goal is to use T1M6 to activate Z1 and T2M6 to activate Z2. I've tried implementing Python remapping, but I'm encountering the following error:
AttributeError: module 'linuxcnc' has no attribute 'remap_command'
Here’s what I’ve tried so far:
1. Created a Python remap script (tool_remap.py).
2. Updated my INI file to include the Python remap.
3. Tested NGC subroutines as an alternative.
My current setup:
- LinuxCNC version: 2.9.3
- INI file configuration: [paste INI file]
- Python script: [paste Python script]
- Error logs: [paste error logs]
Could someone please help me resolve this issue? Thank you!
Last edit: 1 year 9 months ago by pd_2832.
1 year 9 months ago #320218 by Aciera
Please attach ini file and error log.
All I can see at the moment is:
# def tool_remap(self, **words): # command = linuxcnc.command() # stat = linuxcnc.stat() # stat.poll()
Here you were confusing python remaps with the python interface.
The following user(s) said Thank You: pd_2832
1 year 9 months ago - 1 year 9 months ago #320223 by pd_2832
I am using the remap_subs feature in LinuxCNC to control the Z-axis activation for multiple Z axis. Currently, I have implemeted below things:
M428 activates the Z1 axis.
M429 activates the Z2 axis.
However, my goal is to have the activation as mentioned below:
When executing T1 M6, the Z1 axis should be active.
When executing T2 M6, the Z2 axis should be active.
How can I modify the remap logic to achieve this behavior?
Here in gcode file there is T1M6 for Z1 axis instead M428 and T2M6 for Z2 instead of M429.
If i use M428 and M429 in gcode file on the place of T1M6 and T2M6 all things work perfectly but I dont want to change my gcode file how to implement above thing?
1 year 9 months ago - 1 year 9 months ago #320231 by Aciera
You might want to try a simple ngc remap like this first:
Save this as 'm6remap.ngc' in your './remap_subs' folder
o<m6remap>sub M66  E0 L0  ;force synch ;(debug, tool: #<_selected_tool>) o1 if [#<_selected_tool> EQ 1]   (print, Tool 1 - Switching to Z1)   M428 o1 elseif [#<_selected_tool> EQ 2]   (print, Tool 2 - Switching to Z2)   M429 o1 else   (print,Unknown tool: #<_selected_tool>) o1 endif o<m6remap>endsub
Add this to the [RS274NGC] section of your ini file:
REMAP = M6    modalgroup=6   ngc=m6remap
Last edit: 1 year 9 months ago by Aciera.
The following user(s) said Thank You: pd_2832, Charlie
1 year 8 months ago #320470 by pd_2832
Hello,
Thanks for your suggestion, as its working properly, I am able to run both Z axis perfectly.
Time to create page: 0.257 seconds
