Linear ATC in Linuxcnc
- Charlie
31 Jan 2025 09:49 #320217
by Charlie
Linear ATC in Linuxcnc was created by Charlie
Hello,
I am working on linear ATC and my machine is working fine but I want to make that dynamic like now its x,y,z coordinates are set in ngc file for different tool, but i want that data of every tool position dynamically like for every machines user can enter tool positions once and then its working as per data.
31 Jan 2025 10:56 #320224
Replied by andypugh on topic Linear ATC in Linuxcnc
Have you seen the sim/axis/remap/rack-toolchange config?
That uses a remap of the M6 command to work out where it needs to look for each tool.
- Charlie
14 Feb 2025 05:34 #321506
by Charlie
Replied by Charlie on topic Linear ATC in Linuxcnc
Can We use tool.tbl data as position of tool, or its only use for setting tool offset. And yess then how?
ATC possible direcly using tool.tbl ?
Time to create page: 0.103 seconds
