does the EdingCNC CPU5A4E work with LinuxCNC
- piflixe
- Thank you received: 5
03 Feb 2025 08:49 #320477
by piflixe
does the EdingCNC CPU5A4E work with LinuxCNC was created by piflixe
Dear LinuxCNC community!
We purchased a second hand CNC router from BZT and it came with a CNC control from EdingCNC and an Ethernet-based control card called CPU5A4E . Since would like to avoid redoing all the wiring and the general concept of the CNC control seems to be quite similar yet I really appreciate the functionality and expandability of LinuxCNC I was wondering if the CPU5A4E can be used with LinuxCNC. Did anyone try this?
Kind regards, Felix
Kind regards, Felix
- meister
- Thank you received: 502
03 Feb 2025 10:30 #320485
by meister
Replied by meister on topic does the EdingCNC CPU5A4E work with LinuxCNC
the only way to use the board directly would be remora, but i don't know of a PIC version.
But if you have the pin assignment of the DB25+DB9 sockets, you can build an adapter to go to a mesa card, for example
Time to create page: 0.168 seconds
