- LinuxCNC
- General LinuxCNC Questions
- No motion LinuxCNC Debian 12 Bookworm PREEMPT-RT ISO, same config works on 2.8
- GBTig
04 Feb 2025 00:30 #320549
by GBTig
No motion LinuxCNC Debian 12 Bookworm PREEMPT-RT ISO, same config works on 2.8 was created by GBTig
I've got a 3 axis mill that is running Linux 2.8 on a 32-bit Debian install using a Mesa 6i25 / 7i76 combo.
I've installed LinuxCNC 2.9.4 on a new hard drive from the LinuxCNC Debian 12 Bookworm PREEMPT-RT ISO and have copied the config files from the 2.8 install. LinuxCNC 2.9 starts using those config files without any issue and I've got comms with the Mesa cards but I can't move any of the axes (this also means I can't home the machine so anything that requires homing can't be done/tested).
It's probably something fairly simple perhaps with some config requirement change from 2.8 to 2.9 but I've read the documentation and nothing noted in there applies to my setup.
Any ideas on how I can go about diagnosing this issue? I've made no hardware changes to the machine and swapping the 2.8 hard drive back in has everything working properly.
- unknown
- Thank you received: 323
04 Feb 2025 04:41 #320568
by unknown
Replied by unknown on topic No motion LinuxCNC Debian 12 Bookworm PREEMPT-RT ISO, same config works on 2.8
As a first step please post ini & hal files.
- GBTig
04 Feb 2025 05:08 - 04 Feb 2025 05:12 #320571
by GBTig
Replied by GBTig on topic No motion LinuxCNC Debian 12 Bookworm PREEMPT-RT ISO, same config works on 2.8
Here's my .hal and .ini file.
It's a pretty simple 3-axis setup with stepper motors. Was initially running 2.7 for many years then last month tried out 2.8 (which automagically converted my ini file) and I made some small pin name changes to reflect the differences in going to 2.8.
Last edit: 04 Feb 2025 05:12 by GBTig.
- Thank you received: 4150
04 Feb 2025 19:29 #320641
Replied by rodw on topic No motion LinuxCNC Debian 12 Bookworm PREEMPT-RT ISO, same config works on 2.8
For time like this, I generally make a now config with pncconf with some rough settings. Once you see movement, then cut and paste stepper settings and pins from your old config.
- LinuxCNC
