systematic drift on arcs
19 Feb 2025 21:04 #322017 by Meichinger
Replied by Meichinger on topic systematic drift on arcs
If you are not using reset mode (Not sure if the RPI can do this)
The step pulse width is the base period.
Drifting in a (mod) 45 degree angle suggests crosstalk to me.
Maybe a loose ground or 5V common in the step wiring?
That's it! Somehow the stranded wire connecting d- and p - to GND broke in the ferrule. After I replaced the wire, the drifting is gone!
Thanks!
The following user(s) said Thank You: Hakan
Time to create page: 0.134 seconds
