Indivudual home buttons - EMC2-Axis
07 Feb 2025 01:01 #320864 by slowpoke
Indivudual home buttons - EMC2-Axis was created by slowpoke
On my mill there are individual buttons to home, X, Y, Z
On my lathe (EMC2) there is only a home all button.
I would like to be able to home the two axis X & Z independently.
Joint 0 is the X axis, and Joint 1 is the Z axis
How do I go about getting individual home buttons to display and work in EMC2?
For the moment I'm not planning on using actual home switches, just homing from the GUI.
Thanks,
Jeff
07 Feb 2025 09:03 #320896 by rodw
Replied by rodw on topic Indivudual home buttons - EMC2-Axis
EMC2 is a historic name for Linuxcnc so not very helpful
What GUI?
What version?
07 Feb 2025 09:43 #320898 by slowpoke
Replied by slowpoke on topic Indivudual home buttons - EMC2-Axis
What GUI?
What version?
2.93 Axis (for now will explore other GUI's when I have everything sorted out)
07 Feb 2025 09:48 #320899 by rodw
This is a great strategy!
I think in the machine menu, there is a homing menu for each axis but I don't have a sim handy to check.
The following user(s) said Thank You: slowpoke
07 Feb 2025 14:21 #320911 by cakeslob
Replied by cakeslob on topic Indivudual home buttons - EMC2-Axis
I think in axis, I think it has to do with the ini entry HOME_SEQUENCE. I think if you remove that entry, it will remove home all button
07 Feb 2025 14:31 #320912 by slowpoke
You are correct, that works.
Thank you!
Time to create page: 0.093 seconds
