From Grbl to linuxcnc
09 Feb 2025 19:11 #321096 by Esz2
From Grbl to linuxcnc was created by Esz2
Im an electronics technician located in Denmark with an hobby interest in mechanical design, cnc milling and additive manufacturing.
A couple of years ago I bought an cnc router with zero experience in the field. The building and electrical parts where a breeze and the grbl controller that I bought back then was an easy thing to flash with fluidNC and get going.
Now I'm going into more advanced features and adding an self designed atc system hereby arose the need for a more capable controller. The choice settled on the Mesanet 7c80 due to form factor with the rpi and the number of i/o without the need for an daughterboard.
I have experience with rpi/arduino/esp32 projects and have worked a limited bit with commercial fpga cards before.
I have never worked with Linuxcnc before but settled on this environment and the mesa board due to:
1. active community
2. Full customization
So the big question is, where do I begin? What would be a good course of action to get going in an orderly manner?
The hardware:
clossed loop steppers and drivers
XYYZ + AB (possible used to manipulated the ATC later)
inductive sensors on all axis
several solunoidvalves (mist and air)
several relays (pumps and spindle light)
surface probe
tool lenght sensor
several failsafe and e-stops
ballscrews on all axis
The atc system will be an add on later and will not be a part of the initial setup.
The electrical part is going to be an non issue for me I have already planned this from the drawings in the 7c80 manual.
Thanks in advance
09 Feb 2025 19:43 #321103 by andypugh
Replied by andypugh on topic From Grbl to linuxcnc
Well, to get a basic config and axes moving, I would suggest running the pncconf wizard. (though I don't know for sure if that supports the 7C80)
Even if it doesn't you can choose a different board and at least get the required config files set up in the folder structure, even if the details of the board name are not 100% correct.
09 Feb 2025 19:45 #321107 by andypugh
Though perhaps I should have started at the beginning:
Install the correct Pi image from here:
www.linuxcnc.org/downloads/
09 Feb 2025 23:30 #321130 by unknown
Replied by unknown on topic From Grbl to linuxcnc
RPi5 will need to have hm2_spix driver loaded
RPi4 will need to have hm2_rpspi driver loaded
The following user(s) said Thank You: Esz2
12 Feb 2025 18:10 #321359 by Esz2
Replied by Esz2 on topic From Grbl to linuxcnc
I have downloaded the image, edited the files on the image and are able to remote into the pi.
SPI has been enabled from console.
Currently waiting on time to do the hardware modification of desoldering the male header and soldering on a female header on the bottom of the Pi 4
12 Feb 2025 18:46 - 12 Feb 2025 18:47 #321366 by Esz2
So i've been tinkering a little and getting to learn the new enviroment.I have made my basic configuration of a .HAL file for linuxCNC, don't mind that the I/O pins are not defined correct in relation to my hardware.When defining the outputs i stumpled upon the .CFG file that defines for example RS-485 spindle control over modbus.I have linked the 2 files as .txt could anyone please give feedback and advice.TIA.
Last edit: 12 Feb 2025 18:47 by Esz2. Reason: Files missing
