try to invert the enable on my mesa 7i96s
11 Feb 2025 17:07 #321246 by flexbex
Hi I try to invert the enable logic on my mesa 7i96s without luck.# --- MACHINE-IS-ENABLED ---setp hm2_7i96s.0.ssr.invert.00 truenet machine-is-enabled => hm2_7i96s.0.ssr.00.out-00
But the signal is still not inverted. Any help on this?
my connection is
5v ->   ena+
ena- ->  out+(mesa)
out- -> gnd
now it is when it is enabled the driver is disabled
11 Feb 2025 17:53 #321254 by PCW
inverting the SSR output will work _BUT_ it will not have the desired effect
because after a LinuxCNC fault or before LinuxCNC is running, the drives will
be enabled.
If you cannot invert the _DISABLE_ function on your drive, its best to logically
invert the signal externally, one way would be:
+5V --> 47 Ohm 1W --> All drive _DISABLE_+ inputs
GND --> All drive _DISABLE_ - inputs
7I96S OUT0+ --> All drive _DISABLE_+ inputs
7I96S OUT0-   --> GND
The following user(s) said Thank You: flexbex
12 Feb 2025 05:17 #321319 by flexbex
Replied by flexbex on topic try to invert the enable on my mesa 7i96s
That could work. But why do you choose a 47 ohm 1W resistor? That sounds so small. As a pull up I normally choose more in the 1k range
12 Feb 2025 09:33 #321331 by flexbex
OK thank you your suggestion worked with a 1k resistor.
12 Feb 2025 14:54 - 12 Feb 2025 14:55 #321343 by PCW
I chose 47 Ohms because most OPTO inputs on step drives need
significant current (up to 10 mA each). I wanted to make sure that
The voltage at the (paralleled) ENA+ input was close to 5V when the
SSR was off.
Last edit: 12 Feb 2025 14:55 by PCW.
Time to create page: 0.737 seconds
