PC for linuxcnc
- Abdulkareem
13 Feb 2025 16:54 - 13 Feb 2025 16:54 #321448
by Abdulkareem
PC for linuxcnc was created by Abdulkareem
i am assembly new pc for my machine , i found CPU AMD RYzen 5 7600X that has 6 cores perfomrance and has high frequancy speed and large cache , from my research the PREEMPT RT kernal to performe better the cores should be performance only without effeciency cores and the CPU speed per core should be high, does anyone has tried this CPU for their machine and what about the overheating of the CPU should i be worried about it?
Last edit: 13 Feb 2025 16:54 by Abdulkareem.
- Thank you received: 7488
13 Feb 2025 17:06 #321450
Replied by tommylight on topic PC for linuxcnc
I have used almost all of the older Ryzen processors, like 3500x, 3600, 3700x, 3900x, 5500, 5600x, 5600g, 5800x, 5900x, 5950x and 5500u and 5700u, all worked fine except one combo of 3500x with a good motherboard that for some strange reason had terrible latency.
As for overheating, the 7000 series heat up the most and they are programed to run at max possible speed until they get to 95 degree C, then throttle down. Meaning 7000 are the worst if heat is concerned, although they can handle it without issues, ever, but throttling down might cause latency spikes.
7000 series also uses AM5 socket/boards and DDR5 memory, all have higher prices, so right now i can get a 12 core 5900x system for the same price of the 7600x system with 6 cores.
Time to create page: 0.095 seconds
