Yes, buying the 7i76e might be a good idea, but its difficult to get (out of stock everywhere) and i would wish to not need to rewire anything and configure.
Of course I could ask or look for a pc setup that works 100% with the newest rtai kernel and buy the same hardware, but its just strange that I cannot get that machine that worked really well with wheezy not working on debian 12.
On tomorrow i will try a couple more bios settings but all energy saving functions are disabled and I know I didn't had to fix so many things to get a jitter of about 8000.
@tommylight: this I have solved already and the machine sounds and works by jogging perfectly fine now, but I still get unexpected realtime error on task 1 on start up.
Currently I mostly do changes in the cpu ratio and other cpu settings like cpu bus frequency and if I setup a wrong value, lets say, cpu frequency 165 instead of 120 then the machine might make that strange movement, smooth but not all the time.
I attach 2 pictures of one windows screen (tweaker), so that you see the options. That are not anymore the current settings. Tomorrow I can show pictures of the other options available but I am sure it's setup correct.
In grub config I have only what was already there: "quiet" and I added "isolcpus=5" to it. I believe with wheezy I had isolcpus=1,2,34,5, but I am not sure anymore.
The cpu is a amd phenom ii x6 1055t.
