Mesa 7i97T + 7i84 + 7i78 configuration
19 Feb 2025 10:46 #321972 by JB-Motoring
Mesa 7i97T + 7i84 + 7i78 configuration was created by JB-Motoring
Hey guys,
it's been a while since my last post. :)
I am currently working on retrofitting a DMG 50 with analog +-10V Simodrives.
The Mesa's for this project are already laying on my desktop.
I am coming from 7i92 + 7i77, so many tutorials for these builds. Now with the 7i97T i am kinda lost when it comes to flashing.
I need a bin file for the combination :
7i97T
7i84 - over TB4 (ethernet)
7i78 - over P2
Can anyone bring some light into this? Or already used this combination?
The 7i78 is "only" for backup if more encoders are needed- so maybe I can start the config without it.
Thanks in advance for any help guys :))
BR Joel
19 Feb 2025 12:33 #321978 by JT
The smart serial card does not need firmware. The 7i97t_7i78d.bin firmware is what you want and you can flash it with the Mesa Configuration Tool .
JT
The following user(s) said Thank You: JB-Motoring
19 Feb 2025 15:05 #321992 by JB-Motoring
Replied by JB-Motoring on topic Mesa 7i97T + 7i84 + 7i78 configuration
Hey JT,
thanks mate! I finally got it "running".
I will try some things tomorrow. What do I have to modify in the HAL to accept the 7i78? Or is it working already? :)
Thanks!!
BR
20 Feb 2025 07:59 #322037 by JB-Motoring
So coming to the next "problem"....
The machine uses Heidenhain LS486 Linear scales (XYZ) and RON285 rotary encoders (A/B).
What would be the best way to get that signal into the MESA?
Buying 5 IBV boxes?
Thanks guys!
BR
21 Feb 2025 10:00 #322187 by JB-Motoring
Hey guys,
so I got Linuxcnc running- And I would like to test all i o 's on the bench before moving to the machine.
As soon as I hit enable (F1/F2) all assigned Analog Outputs show -10V.
There is no encoder or drive connected, just the naked Mesa on the desk.
How can I handle this to see, if the output is working?
Thanks guys!
21 Feb 2025 15:07 - 21 Feb 2025 15:09 #322208 by PCW
Replied by PCW on topic Mesa 7i97T + 7i84 + 7i78 configuration
This is incorrect:
setp hm2_[MESA](BOARD).0.pwmgen.00.offset-mode 0 # offset mode so 50% = 0
Offset mode must be set true on the 7I97/7I97T:
setp hm2_[MESA](BOARD).0.pwmgen.00.offset-mode 1 # offset mode so 50% = 0
This is incorrect as well:
setp hm2_[MESA](BOARD).0.pwmgen.00.output-type 2 #PWM pin0
PWM mode must be set for type 1 (PWM+DIR):
setp hm2_[MESA](BOARD).0.pwmgen.00.output-type 1 #PWM pin0
Last edit: 21 Feb 2025 15:09 by PCW.
24 Feb 2025 06:07 #322457 by JB-Motoring
Thanks PCW!!
I will try this in a few moments.
I will report, if it is working :)
BR
25 Feb 2025 10:48 #322574 by JB-Motoring
Okay,
I managed to get the encoders and Analog outputs working :)!
The next thing would be to get the io's working correctly.
I attached the corrected hal and ini- also the thing that comes from "halcmd show pin > all_linuxcnc_pins".
It feels like, I am missing some ios.
Is that correct? What about the sserial init. at the beginning of the .hal?
Thanks guys :)
26 Feb 2025 04:30 #322644 by Sziggy_NC
Replied by Sziggy_NC on topic Mesa 7i97T + 7i84 + 7i78 configuration
What io's do you think you are missing?
I notice that your digital in and digital out are empty. I had to use this to control my tool changer, pnumatic gripper, and to read spindle & tool changer sensors. It is how the O-code program can control the outputs and check the inputs.
I linked my door lock to some classic ladder pins.
Ex: "net door-open classicladder.0.in-01 => hm2_7i97.0.7i84.0.0.input-00"
The sserial seems like it might be right. Check to see if you can see the 7i84 pins in halshow. I had to expand pins > 7i97 > 0 > then I could seen the 7i84. If it doesn't work try replacing the XXXXX with zeros to become "sserial_port_0=00000000" It is what works for my 7i97T + 7i84 setup.
26 Feb 2025 07:03 #322664 by JB-Motoring
Maybe you can check the pinout here attached.
I will do some further tests now- coming from 2.8... and a 7i77, this stuff is quite "all new" now with ct ect. :D
Thanks guys!
BR
Time to create page: 0.344 seconds
