global named parameter error
  • MaxEkb77
  • MaxEkb77's Avatar Topic Author
  • Senior Member
  • Senior Member
22 Feb 2025 11:31 #322267 by MaxEkb77
global named parameter error was created by MaxEkb77
Hello.
On linuxcnc 2.10, 2.9. (axis, gmoccapy)
I try enter in MDI  " #<_varzag>=55 "
after i try load ngc file when using that variable " #100=#<_varzag>.
I got error "Named parameter #<_varzag> not defined" , programm working fine - why showed that error ?
22 Feb 2025 15:41 #322275 by MaHa
Replied by MaHa on topic global named parameter error
You can solve that this way:
o800 IF [#<_task> EQ 1]
     #100=#<_varzag>
o800 ENDIF
The following user(s) said Thank You: MaxEkb77
  • MaxEkb77
  • Senior Member
  • Senior Member
23 Feb 2025 09:00 #322349 by MaxEkb77
Replied by MaxEkb77 on topic global named parameter error
Thank you. working
Time to create page: 0.244 seconds
