Linuxcnc hotspot on raspberry pi
22 Feb 2025 18:46 #322288 by Lpkkk
Linuxcnc hotspot on raspberry pi was created by Lpkkk
Hello did anyone tried to set up a hotspot on raspberry pi to connect remotely?
22 Feb 2025 19:05 #322290 by unknown
Replied by unknown on topic Linuxcnc hotspot on raspberry pi
No and if you want to you're on your own. Totally beyond the scope of this forum.
And not a good idea for too many reasons.
22 Feb 2025 20:24 #322302 by tommylight
Replied by tommylight on topic Linuxcnc hotspot on raspberry pi
Question should be
How to set a hotspot on Linux?
Any Linux distro that uses network manager = easy, it goe something like:
-right click on the network icon located up or down on the right side close to the clock
-choose "edit connections"
-double click on the wifi connection
-go to "Wi-Fi" tab
-select "hotspot" from the drop down menu and add info as neede like BSSID etc
-click save
-close
left click on network manager and select the wifi network to reconnect
done.
22 Feb 2025 22:22 #322315 by unknown
That would work if network manager was the method used to manage the interfaces and network-manager-gnome was installed. But that's not the way the images are built.
And honestly if you don't setup a firewall as well.....
