Is it possible to program by hand with Linuxcnc?
- Lehmeier
23 Feb 2025 16:20 #322374
by Lehmeier
Is it possible to program by hand with Linuxcnc? was created by Lehmeier
Hello!
I am looking for a CNC system with which I can practise programming by hand. Preferably with a GUI that allows operation like on the machine.
It should not only work as a machine controller but also as an offline system on the computer.
I am also interested in whether the current Linuxcnc is compatible with Pal, Sinumeric and / or Heidenhain.
Kind regards R.Lehmeier
Translated with DeepL.com (free version)
- Thank you received: 7488
23 Feb 2025 17:06 #322379
Replied by tommylight on topic Is it possible to program by hand with Linuxcnc?
LinuxCNC has plenty of included simulation configurations, and several GUI's you can use.
You can even use it booted from USB, without installing it at all, or install it on a machine and still use sim configs, pretty much anything you can think of you can do, within reason.
The following user(s) said Thank You: Lehmeier
- Thank you received: 2176
23 Feb 2025 17:39 #322381
Replied by Aciera on topic Is it possible to program by hand with Linuxcnc?
You seem to have asked this very same question some years ago:
forum.linuxcnc.org/38-general-linuxcnc-q...rogrammieren?start=0
Nothing has fundamentally changed since so those answers are still valid.
- Lehmeier
23 Feb 2025 18:02 #322382
by Lehmeier
Replied by Lehmeier on topic Is it possible to program by hand with Linuxcnc?
Ok. then I'll see if there's something for me.
Since I have no idea how to install the GUI's or which one I should use, I would be open to suggestions.
23 Feb 2025 18:52 #322384
Download ISO from here
www.linuxcnc.org/iso/linuxcnc_2.9.4-amd64.hybrid.iso
Write it to a USB, use that USB to boot the PC from it (google how to do that for your actual PC by entering BIOS), do NOT install anything just use Live mode, go to CNC menu and choose LinuxCNC, on the opened window on the left side choose sim and start any of those sims, play with them, close, start another sim, etc etc.
- Lehmeier
23 Feb 2025 19:07 #322386
by Lehmeier
Thanks for the tip. I will give it a try.
EndeavourOS only has 2.9.3 and there are problems installing it.
A live version might be a better idea - especially to see if it works the way you want it to.
Time to create page: 0.098 seconds
