How to access rt pins in user space
- RushA
24 Feb 2025 03:25 #322430
by RushA
How to access rt pins in user space was created by RushA
I create some pins in the RT module, now I want to read and write pins' value in user space.I use the following code,but it failed.Is there any way to access RT module pins in the user space? The environment is Ubuntu20.04+xenomai3.1+linuxcnc2.9.Thanks!
int compId;
int ret;
hal_float_t *pin_value;
// init HAL
compId = hal_init("user_program");
if (compId < 0) {
rtapi_print("HAL init failed\n");
return -1;
pin_value = (hal_float_t*)hal_malloc(sizeof(hal_float_t));
ret = hal_pin_float_new("kernel_pin", HAL_IN, &pin_value, compId);
if (ret < 0) {
rtapi_print("getting or creating pin failed!\n");
hal_exit(compId);
return -1;
ret = hal_link("user_program.kernel_pin", "ALT.I2600");
if (ret < 0) {
fprintf(stderr, "cann't bind signal!\n");
hal_exit(compId);
return -1;
hal_ready(compId);
//*pin_value = 123.45;
//rtapi_print("value is: %f\n", *pin_value);
hal_exit(compId);
It prints some messages:
HAL: initializing hal_lib
HAL: initializing component 'user_program'
HAL: component 'user_program' initialized, ID = 28
smalloc_up: shmem available 1386552
HAL: ERROR: pin_new(kernel_pin) called with already-initialized memory
HAL: creating pin 'kernel_pin'
HAL: ERROR: data_ptr_addr not in shared memory
int compId;
int ret;
// init HAL
if (compId < 0) {
return -1;
if (ret < 0) {
hal_exit(compId);
return -1;
if (ret < 0) {
hal_exit(compId);
return -1;
hal_ready(compId);
hal_exit(compId);
04 Mar 2025 16:18 #323156
Replied by andypugh on topic How to access rt pins in user space
One option might be to create complementary pins in your userspace module and link them in the HAL layer.
Can you give more details about what you are trying to do? There are a few examples of existing drivers with realtime and userspace pairs. These tend to communicate with private shared memory.
linuxcnc.org/docs/stable/html/man/man1/halsampler.1.html
linuxcnc.org/docs/stable/html/man/man9/sampler.9.html
For example.
For example.
- RushA
02 Apr 2025 08:50 #325501
by RushA
Replied by RushA on topic How to access rt pins in user space
hi,thank you for your reply!
I have two modules running in realtime space. One is ethercat module, the other is shared memory module. The ethercat module tranfers data to shared memory module through pins, and I want to get these data from shared memory module in user space.
- RushA
02 Apr 2025 08:53 #325502
by RushA
Can you give me some examples? Code or something.
- Thank you received: 2176
02 Apr 2025 09:23 #325504
Replied by Aciera on topic How to access rt pins in user space
The source code for the suggested example components can be found here:
github.com/LinuxCNC/linuxcnc/blob/master...components/sampler.c
github.com/LinuxCNC/linuxcnc/blob/master...onents/sampler_usr.c
Additionally this component might also be of interest:
github.com/LinuxCNC/linuxcnc/blob/master...omponents/streamer.c
- RushA
03 Apr 2025 00:34 #325563
by RushA
That's great, thank you!
- Thank you received: 2181
03 Apr 2025 02:30 #325569
Replied by cmorley on topic How to access rt pins in user space
The HAL python module allows reading or arbitrary pins and signals without connecting to them.
It's written in C++ but shows the process and borrows C code from HAL cmd.
- RushA
03 Apr 2025 05:50 #325586
by RushA
hi,here's another question. I want to read from and write to the module (for example the shared memory module in realtime space) through pins in user space.How can I solve the problem? Is there any code about this?
- RushA
03 Apr 2025 05:55 #325587
by RushA
hi, thanks!
Is there any code or links to refer to?
Time to create page: 0.220 seconds
