Getting QTDragon settings values from within remap.py
- JohnnyCNC
- Thank you received: 115
24 Feb 2025 22:44 #322536
by JohnnyCNC
Getting QTDragon settings values from within remap.py was created by JohnnyCNC
How can I get the X & Y values of the Tool Sensor Location from Settings tab in QTDragon_HD from with remap.pyThis code below works when getting the values from the .ini file but I would rather use the values from QTDragon’s screen.self.execute("G53 G0 X[#<_ini[TOOLSENSOR]X>] Y[#<_ini[TOOLSENSOR]Y>]")
Thank You.
Thank You.
- Thank you received: 2181
25 Feb 2025 06:07 #322558
Replied by cmorley on topic Getting QTDragon settings values from within remap.py
You would need to modify qtdragon to output though settings as HAL pins, then you can read them in a ngc program.
- JohnnyCNC
25 Feb 2025 13:05 #322582
by JohnnyCNC
Replied by JohnnyCNC on topic Getting QTDragon settings values from within remap.py
By ngc program does that also include a remap done in Python?
I thought the values were stored in self.lineedit_list.sensor_x and self.lineedit_list.sensor_y but I can't seem to get at them.
26 Feb 2025 06:48 #322660
Something like:
x = float(self.w.lineEdit_sensor_x.text())
y = float(self.w.lineEdit_sensor_y.text())
26 Feb 2025 06:50 #322662
You can read HAL pins in python remaps
- JohnnyCNC
26 Feb 2025 13:37 #322695
by JohnnyCNC
Thanks. I will keep trying. I had the exact same two lines in my code and it caused an error that states: m6remap remap error.
print("Before test code") <- This prints then the error text is next.
print("After test code") <- Does not print.
26 Feb 2025 19:09 #322729
Those lines won't work in the remap (if that is what you meant) you would need to connect those to a HAL pin in qtdragon, then read the pins n the remap. I'm at work right now but will see if I can make a sample file for qtdragon tonight. You use master and regular or HD dragon?
- JohnnyCNC
26 Feb 2025 19:45 #322733
by JohnnyCNC
Thanks Chris,
Yes, that is what I meant. I am using 2.9.4 and the HD version of QTDragon.
No hurry at all. I've got my m6remap working really well. It allows using a mix of fixed and variable length tools where the variable length ones get automatically measured during the manual tool change. I'm just adding the finishing touches. I use this in conjunction with Basic Probe.
Thanks again.
Thanks again.
- JohnnyCNC
27 Feb 2025 03:27 #322768
by JohnnyCNC
Chris,
With ChatGPT's help I think I have found enough examples to have a go at this. I'll report back with how it goes. Thanks for your guidance.
