Modify AXIS GUI
- Thank you received: 2181
01 Mar 2025 16:40 #322936
Replied by cmorley on topic Modify AXIS GUI
Here is a camera only panel. Well it still has crosshair - is that ok?
- noqui
02 Mar 2025 00:29 #322975
by noqui
Replied by noqui on topic Modify AXIS GUI
I have installed Qt Designer,
How can I edit the pre installed panel ? I am not sure where is the file?
Thanks a lot
Thanks a lot
- noqui
02 Mar 2025 02:01 #322982
by noqui
tommylight, I haven't seen before, the camera widget you sent me. I'll try to connect it with a camera i have with this computer.
Thanks a lot.
Thanks a lot.
- Thank you received: 7488
02 Mar 2025 02:17 #322985
Replied by tommylight on topic Modify AXIS GUI
You mean Chris ?
The following user(s) said Thank You: noqui
- noqui
02 Mar 2025 14:16 #323018
by noqui
Sorry tommylight. I thought you added cammera.zip, but it was cmorley. So sorry.
- noqui
02 Mar 2025 14:38 #323019
by noqui
I think i found the AXIS.GUI source code in qtaxis.ui to edit it with Qt 5 Designer . Is this correct?
Thanks a lot.
Thanks a lot.
02 Mar 2025 17:30 #323031
No worries at all, just making sure the credit goes where credit is due.
Thank you.
Thank you.
Time to create page: 0.119 seconds
