Latency testing and questions V2.93 Axis
- slowpoke
- Thank you received: 28
26 Feb 2025 13:52 #322699
by slowpoke
Latency testing and questions V2.93 Axis was created by slowpoke
I'm using the following hardware for my lathe:
Lenovo Yoga with i5-5200 2 core
Mesa 7i96s - with 3 encoders, 2 MPG's , 2 servo drives and all I/O
With stock BIOS settings I was getting the pop up latency warning, with revised BIOS settings the warning appears to be gone.
BIOS setting changes that seemed to make a difference:
Pre BIOS changes: (all times in uS)
Max int Max Jitter
Servo thread: 1019 51
Base thread: 182 158
Post BIOS changes: (all times in uS)
Max int Max Jitter
Servo thread: 1009 51
Base thread: 45 24.7
A few questions:
- All power saving - disabled
- Hyper-threading - disabled
- Intel Network Frame Forwarder - disabled
Max int Max Jitter
Max int Max Jitter
A few questions:
- It's not clear to me how critical these results are when using a 7i96s for encoder and step generation?
- Max jitter for the servo thread seems quite good, however base thread seems marginal, comments please?
- I did not mess with isolcpus, and I'm not sure how or if I should?
- Thank you received: 5330
26 Feb 2025 15:48 #322712
Replied by PCW on topic Latency testing and questions V2.93 Axis
Latency is basically unimportant with Mesa hardware _if_ you never get timeouts
Also the latency test does not test network latency which is more important for
Ethernet connected cards.
To check network latency:
sudo chrt 99 ping -i .001 -c 60000 -q 10.10.10.10
(will run for ~ 1 minute and print stats)
Assuming the Ethernet card is set for 10.10.10.10
Things that improve network latency:
isolcpus to last CPU, and pinning the Ethernet IRQ to the last CPU
disabling power management, disabling Intel AMT
The following user(s) said Thank You: slowpoke
Time to create page: 0.156 seconds
