Rotating the g54 coordinate system.
27 Feb 2025 07:53 #322778 by flexbex
Rotating the g54 coordinate system. was created by flexbex
Hi let's assume I have a work piece not perfectly square on my table. Could I touch of one side of the workpiece on two points with a probe. Then I would define this as one of the axis of g54 coordinate system. Let's say y axis. So that it would be rotated to g53?
27 Feb 2025 09:42 #322779 by rodw
Replied by rodw on topic Rotating the g54 coordinate system.
yes, but I think rotation is applied to the current coordinates. qtdragon and QTplasmac already support part rotation the way you describe..
07 Apr 2025 22:32 #325888 by pgf
Replied by pgf on topic Rotating the g54 coordinate system.
I've just implemented this for myself.
I already have autoprobe routines that set g54 parameters for X, Y, and Z. I augmented my autoprobe functions to log the x and y values of every completed probe, along with the g54 offsets in effect at the time.
When I have a rotated part, I touch it twice, along a surface that's parallel to its twisted X axis. That gives me two new log entries. I have a script that reads those entries, and calculates d = atan ( (y2 - y1) / (x2 - x1) ), after correcting the x and y values with the offset information.
The script prints the result in degrees. In fact, the script simply prints the necessary g-code: "G10 L2 P0 R $angle", which I then pasted into the MDI window.
The following user(s) said Thank You: timo
08 Apr 2025 07:34 - 08 Apr 2025 07:36 #325900 by skydyver
Replied by skydyver on topic Rotating the g54 coordinate system.
When I have a rotated part, I touch it twice, along a surface that's parallel to its twisted X axis. That gives me two new log entries. I have a script that level devil  reads those entries, and calculates d = atan ( (y2 - y1) / (x2 - x1) ), after correcting the x and y values with the offset information.
Once you generate the G-code command with the calculated angle, do you have any specific procedures for verifying the machine’s response after you paste it into the MDI window?
Last edit: 08 Apr 2025 07:36 by skydyver.
19 Apr 2025 18:14 #326729 by pgf
Sorry -- I missed this reply earlier. No, nothing specific. But the machine (and the axis preview) seem to do the right thing.
Time to create page: 0.254 seconds
