Built In Wifi Not Working Raspberry Pi 5 and 2.9.4
05 Mar 2025 15:52 #323282 by mindstormmaster1
Built In Wifi Not Working Raspberry Pi 5 and 2.9.4 was created by mindstormmaster1
I installed Linuxcnc on an 8GB Pi5 using this file since I want to use a MESA board, it looked like the right choice.
www.linuxcnc.org/iso/rpi-5-debian-bookwo...25-01-27-0140.img.xz
Everything booted up well(but there was no initial setup wizard like I have seen some people mention), and the install looks good, but I don't see wifi anywhere or network options of any kind. I tried a USB wifi dongle, and that didn't change anything and unfortunately, ethernet is not an option for me. Does anyone have any tips for getting wifi working? Should I have used the other .iso? Thanks!
05 Mar 2025 17:18 #323291 by unknown
I don't know where you saw the info about the setup wizard, but this is absolutely wrong.
As the image is essentially Debian Bookworm you can use the below link to get an idea. Also there is a large sticky thread related to the RPi images, in the Installing Linuxcnc heading.
What other image are you referring to ?
wiki.debian.org/NetworkConfiguration
05 Mar 2025 21:05 #323315 by rodw
to set up, first connect the Ethernet to your router and let it get an IP address via DHCP
To set up wifi, follow the instructions on the downloads page.
Now you have it working if you need to set up for a Mesa card, follow the instructions
linuxcnc.org/docs/stable/html/man/man9/hm2_eth.9.html
06 Mar 2025 01:25 #323322 by unknown
