Machine Jerk When Post process all command CAM
- abdulasis12
- Thank you received: 8
08 Mar 2025 08:15 #323499
by abdulasis12
Machine Jerk When Post process all command CAM was created by abdulasis12
Hi
Now I use Linuxcnc V.2.9.4
I have a problem when Post G-code from Fusion360
If I post 1 post 1 command (Adaptive clearing) it's No jerk
but When I post 3 command in Gcode
1. Adaptive clearing (tool 16) Not jerk
2. Face (tool 15) Not jerk
3. Adaptive clearing (tool 16) Jerking
Step 3 my machine will jerk when entering a curve and Velocity move slow down to 10-30 % feed , And will back to 100% speed when back to linear move .
My post I use
G64
G64 with P
G64 with PQ
Same problem can't solved .
I try
Post Gcode only Step 3. Adaptive clearing it's not have a problem can run full speed and machine not jerk
How I can fix this problem ?
Thank you
Asis
My post I use
G64
G64 with P
G64 with PQ
I try
Thank you
Asis
- abdulasis12
08 Mar 2025 09:13 #323502
by abdulasis12
Replied by abdulasis12 on topic Machine Jerk When Post process all command CAM
I Found a problem
If use FACE process
next step after FACE , not include G64 P Q Line
maybe problem from Post Processor of fusion360
now my post $Revision: 44166 e813d608ccd22fb0949f73fcdb773b434407b131 $
I put G64 with PQ in adaptive clearing step3 now can solved no machine jerky
Problem not from linuxcnc , problem from Post .
Thank you
Asis
If use FACE process
Thank you
Asis
Time to create page: 0.117 seconds
