Incorporating HAL script recommendation (2.7.14 to 2.9.4 conversion of XZC
11 Mar 2025 18:01 #323695 by Lindley
Where do I add the suggested script fix in my configuration?  The converted file from my XZC coordinate system does not work.
Report is attached.  Can provide HAL and INI if needed.
11 Mar 2025 18:11 #323696 by Aciera
The recommendation is not related to your problem, which is here:
HAL: ERROR: function 'pid.s.do-pid-calcs' not found
./Editlindowxzc3-11-25rev2.hal:21: addf failed
So please attach your hal and ini files.
11 Mar 2025 18:36 #323697 by Lindley
Per request.  Thanks for quick response.
11 Mar 2025 19:38 #323700 by Aciera
in your hal:
change this line
loadrt pid names=pid.x,pid.z,pid.c
to:
loadrt pid names=pid.x,pid.z,pid.c,pid.s
The following user(s) said Thank You: Lindley
11 Mar 2025 22:43 #323710 by Lindley
Made suggested change...another issue.  The provided line was in the file from the conversion script and I totally missed it as I was preparing INI and HAL files base in Imperial values rather than metric.    However, another issue arose: program could not find variable INPUT_SCALE.  I believe this is the updated name for the old (2.7.14) STEP_SCALE.  I changed the INI to reflect this and tried again.  Still an issue.
Notably as I have been working on this configuration conversion.  I have encountered several apparent variable name changes between 2.7.14 and 2.9.4,  Unfortunately I did not create a list which at this point would have been helpful.
In any event here is the set of documents for my latest attempt:
12 Mar 2025 00:04 #323717 by Lindley
FYI: Based on memory and a quick look, it appears the default and maximum velocity and acceleration variables (4 total) have an added "LINEAR" in the name for 2.9.4. This is from comparison of the TRAJ section for 2.9.4 and TRAJ and AXIS in 2.7.14 documentation.  The 2.9.4 document does mention some additional variables that carry over from the conversions involving scale aspects.
12 Mar 2025 07:24 #323730 by Aciera
That error report still refers to the 'pid.s.do-pid-calcs' not being found. Maybe you attached the wrong file?
12 Mar 2025 19:13 #323771 by Lindley
Very possible...wrong file attached.
In the meantime, found several apparent errors in the HAL when comparing to the original version conversion.  Further,  I had to reset the BIOS to defaults for Debian 12 to install and had not reset the serial port address. This should be consistent set of INI, HAL, and error report files.
13 Mar 2025 06:54 #323803 by Aciera
./Lxzc3-12-25rev4.hal:201: Ini variable '[SPINDLE_9]P' not found.
1. Your ini is missing the spindle section while your hal references 'SPINDLE_9' ini entries. Looking at your hal file makes me think that you are not actually using a spindle setup. If that is the case then you might want to completely remove this section from your hal:
#  SPINDLE S
setp   pid.s.Pgain     [SPINDLE_9]P
setp   pid.s.Igain     [SPINDLE_9]I
setp   pid.s.Dgain     [SPINDLE_9]D
setp   pid.s.bias      [SPINDLE_9]BIAS
setp   pid.s.FF0       [SPINDLE_9]FF0
setp   pid.s.FF1       [SPINDLE_9]FF1
setp   pid.s.FF2       [SPINDLE_9]FF2
setp   pid.s.deadband  [SPINDLE_9]DEADBAND
setp   pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp   pid.s.error-previous-target true
net spindle-index-enable  <=> pid.s.index-enable
net spindle-enable         => pid.s.enable
net spindle-vel-cmd-rpm    => pid.s.command
net spindle-vel-fb-rpm     => pid.s.feedback
net spindle-output        <=  pid.s.output
net spindle-vel-cmd-rps       <=   spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs   <=   spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm       <=   spindle.0.speed-out
net spindle-vel-cmd-rpm-abs   <=   spindle.0.speed-out-abs
net spindle-enable            <=   spindle.0.on
net spindle-cw                <=   spindle.0.forward
net spindle-ccw               <=   spindle.0.reverse
net spindle-brake             <=   spindle.0.brake
net spindle-revs               =>  spindle.0.revs
net spindle-at-speed           =>  spindle.0.at-speed
net spindle-vel-fb-rps         =>  spindle.0.speed-in
net spindle-index-enable      <=>  spindle.0.index-enable
sets spindle-at-speed true
13 Mar 2025 16:51 #323850 by Lindley
Correct..do not use spindle control.  Eliminated those sections and references.  CNC now starts until encountering the axis.ngc file for the splash display which is XYZ coordinates instead of XZC. So, struggling trying to replace the file with my old splash file which was in XZC coordinates.  The file is in a read only root directory (usr/share/images/axis.ngc I believe) and I have not yet figured out how to paste in the new file.
In any event, considerable progress and light at the end of the tunnel.
Thanks so much for the assistance and accommodating my limited competence in LINUX.
Time to create page: 0.453 seconds
