- LinuxCNC
- General LinuxCNC Questions
- Incorporating HAL script recommendation (2.7.14 to 2.9.4 conversion of XZC
- Thank you received: 2176
13 Mar 2025 18:49 #323858
Replied by Aciera on topic Incorporating HAL script recommendation (2.7.14 to 2.9.4 conversion of XZC
You can set the file to be loaded on startup by adding this to the [DISPLAY] section of your ini file:If you want no file loaded you can try
OPEN_FILE = /full/path/to/file.ngcOPEN_FILE =""
The following user(s) said Thank You: Lindley
- Lindley
14 Mar 2025 17:53 #323944
by Lindley
Replied by Lindley on topic Incorporating HAL script recommendation (2.7.14 to 2.9.4 conversion of XZC
Success! Known files run as anticipated. Did require tweaking several INI parameters and I am sure more refinements will happen as I develop experience with this version.
I am using to drive a rose engine lathe and thus the reason for the XZC coordinate system.
Thanks again for your patience and assistance.
- LinuxCNC
Time to create page: 0.183 seconds
