New to linuxcnc, basic question for DRO modes with encoded handwheels
18 Mar 2025 05:47 #324167 by rodw
The 7i96s  looses some inputs to run MPGs. I would go with a Mesa 7i76E or the EU version. It has two MPG inputs. Perhpas PCW will be able to add a third. With the 7i76E the machine will run as fast as you can wind the MPG. There is a parllel port example in the docs so its pretty easy to adapt to the mesa card as its just changing the pin names.
The following user(s) said Thank You: directandrew
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
18 Mar 2025 10:41 #324185 by Todd Zuercher
If you go the parallel port route, you will probably find you need to run at least two parallel ports. Encoder inputs can eat up a lot of input pins (3 axis would require 6 input pins.) But when you start to look at multiple parallel ports and buying add on parallel port cards, Mesa starts to look much more appealing. For example a Mesa 5i25/6i25 doesn't cost much more than a 2 port parallel port card, but is much more capable, and you know it is going to work with Linuxcnc, vs the crapshoot compatibility of buying a multi parallel port PCIe card. For example the last PCIe parallel port card I used only sort of half worked until I modified the breakout board by adding some external pull up resistors to some of the pins.
16 Jun 2025 00:34 #330327 by directandrew
Based on what im reading, it does seem ill need a larger card to handle all the limit switches and 3 encoders, one for each hand-wheel. I will prob go RJ45 as the parallel ports are less and less these days.
Thinking this guy, not cheap but one stop shop correct?
store.mesanet.com/index.php?route=produc...id=399&search=7I76EU
Time to create page: 0.269 seconds
