Fusion 360 probe on probe_basic - Probe tripped during non-probe move
26 Mar 2025 06:45 #324942 by bpark
I am trying to enable Fusion 360 probe operation by editing post process and try to run test on probe_basic GUI.
All probe_basic GUI based probe is working well without any problem. however, when I try to run Fusion posted probving I got following error during Fusion ngc based probing process.
[qtpyvcp.plugins.notifications][ERROR]  Probe tripped during non-probe move.
The reason would be probe_basic GUI detected "probe tripped" by Fusion probe ngc while not on probe_basic's probing tab GUI.
Can someone tell me how to disable qtpyvcp.plugins.notifications or enable Fusion probing ngc out of probe_basic's probing tab ?
All the best,
Bernard
02 Apr 2025 13:29 #325515 by andypugh
I don't think that "probe tripped during non-probe move" is generated by probe_basic (or by any GUI). It's built-in to core LinuxCNC.
There are a couple of INI settings in [TRAJ] that might be worth trying, though I don't think that they are quite what you want:
linuxcnc.org/docs/stable/html/config/ini...tml#sub:ini:sec:traj
(right at the end of the section, NO_PROBE_..._ERROR )
It seems likely that the problem is with the Fusion probe routine, though, are you absolutey sure that it isn't making a non-probe move into probe contact?
If you set up the HAL so that motion.probe-input is AND-ed with the motion.motion-type == 5 ( "probing") then you can completely bypass the error report. But it is an error indicatiing a genuiune isssue in most cases.
linuxcnc.org/docs/stable/html/man/man9/m...9.html#MOTION%20PINS
02 Apr 2025 20:33 #325542 by rodw
As Andy says, the error is from Linuxcnc core, not the GUI.
I would be running the probing from probe basic and not get F360 to do anything with the probe (I didn't know you could)
I've used a probe with F360 and qtdragon and it all worked perfectly.
Time to create page: 0.116 seconds
