Can not find -sec TRAJ -var COORDINATES -num 1
- Z3rni3
- Thank you received: 3
27 Mar 2025 13:09 #325052
by Z3rni3
Can not find -sec TRAJ -var COORDINATES -num 1 was created by Z3rni3
Hey,
I'm working with a Pi 5 running LinuxCNC 2.9.4 on a Mesa 7i95T.
After installing Mesact i used it to create a baseconfig for my XYYZ machine.
After adding the second Y axis nothing worked anymore.
Would you please take some time to help me out. Thank you.
It gives me following error:
Debug file information:
Note: Using POSIX realtime
Missing [TRAJ]COORDINATES
6052
6099
Stopping realtime threads
Unloading hal components
attached are my .ini and .hal
6052
6099
- Thank you received: 7488
27 Mar 2025 14:23 #325060
Replied by tommylight on topic Can not find -sec TRAJ -var COORDINATES -num 1
Ini file, axis y / joint 2 section still says AXIS Z
Andit is miss spelled, should be COORDINATES
And
[TRAJ]
COORDIANTES = XYYZPlease Log in or Create an account to join the conversation.
- Z3rni3
27 Mar 2025 14:38 - 27 Mar 2025 19:28 #325063
by Z3rni3
Replied by Z3rni3 on topic Can not find -sec TRAJ -var COORDINATES -num 1
Oh wow... I've been racking my brain because of a spelling mistake...
Last edit: 27 Mar 2025 19:28 by Z3rni3.
Time to create page: 0.099 seconds
