new 2.9.4 no working well.
- masawee
29 Mar 2025 06:19 #325227
by masawee
new 2.9.4 no working well. was created by masawee
i installed new version 2.9.4 and have problem, old 2.8.4 working well and no problems, now i have big problems, if i try open new G-code in ro linuxcnc "open code", then search file location windows go all time black screen and go back to login site. same than has boot all computer, why. same this doing if i try open code come black screen and then go back to open file location first 1-2 time and 3 time go main login screen and has closed all linuxcnc and computer.
but if i open g:code not search rows what file and were have what open, only click open no problem and open code and run cnc good, but if open search rows were file have come all time black screen and go back to main login site again and all softwares has closed,
sorry my english not can tell better what is problem. same if open linuxcnc sometime screen stay blinking wrong and any buttons not can use, need end linuxcnc software and open again then no blinkink screen and can use normal. blinking mean all pictures blink some have normal some black and display blink ad shake.
- HansU
- Thank you received: 217
29 Mar 2025 15:36 #325255
by HansU
You could start by using shorter sentences and upper/lower case letters
AND you should tell us which GUI you are using.
Replied by HansU on topic new 2.9.4 no working well.
Time to create page: 0.248 seconds
