Absolute encoder homing
- Philip Lydin
- Thank you received: 6
31 Mar 2025 19:10 #325433
by Philip Lydin
Absolute encoder homing was created by Philip Lydin
I’m trying to get my machine to home according to the position of the absolute encoders I have. I did the regular set up with ”HOME_ABSOLUTE_ENCODER = 2”. When I turn off the machine at let’s say z=10 and then turn it back on the machine remembers that z is 10. But when I then turn on my servos the encoders which also of course says z is 10 since it is the absolute position. The machine then thinks the machine has moved 10 and therefore z is now 20 on the screen. Is there a way to make the machine start at 0. I can upload the files tomorrow if I don’t find a fix. Regards Philip
- Philip Lydin
01 Apr 2025 08:23 #325464
by Philip Lydin
Replied by Philip Lydin on topic Absolute encoder homing
- TAKUYA
- Thank you received: 4
19 Jan 2026 11:30 #341582
by TAKUYA
Replied by TAKUYA on topic Absolute encoder homing
Hi, having the same kind of issue. Did you find any solution for this?
25 Jan 2026 11:08 #341910
Replied by andypugh on topic Absolute encoder homing
- tiagounderground
- Thank you received: 13
27 Jan 2026 08:43 #341998
by tiagounderground
Replied by tiagounderground on topic Absolute encoder homing
i had the same problem, to overcome this i used home offset=0 and added an offset in pos comand
Time to create page: 0.226 seconds
