Halscope trigger level grayed out
- sajurcaju
- Thank you received: 10
06 Apr 2025 12:49 #325812
by sajurcaju
Halscope trigger level grayed out was created by sajurcaju
When I started halscope, the trigger level slider worked as expected. For some reason it has become non-functional. The slider is gray, no green, no way to adjust it. I've tried restarting halscope and changing trigger channel. It doesn't matter if I'm in Normal or Auto trigger.
Thanks,
Steve
Thanks,
Steve
- Thank you received: 1477
07 Apr 2025 10:55 #325861
Replied by Todd Zuercher on topic Halscope trigger level grayed out
The trigger level is greyed out if the source channel is monitoring a simple bit (on/off) signal or pin. To enable the trigger level slider select a pin or signal that is a float or integer value for the source channel for trigger.
- Fredrancis
08 Apr 2025 09:17 #325910
by Fredrancis
Replied by Fredrancis on topic Halscope trigger level grayed out
Did you make any adjustments to the settings before the trigger level slider became greyed out?When I started halscope, the trigger level slider worked as expected. For some reason it has become non-functional. The slider is gray, no green, no way to adjust it. I've tried restarting halscope and changing trigger channel. It doesn't matter if I'm in Red Light Green Light Normal or Auto trigger.
Thanks,
Steve
- sajurcaju
17 Apr 2025 18:50 #326538
by sajurcaju
Replied by sajurcaju on topic Halscope trigger level grayed out
That makes sense Todd. I was thinking of it as an analog scope.
- sajurcaju
17 Apr 2025 18:52 #326539
by sajurcaju
Yes, but that was probably with a different signal line. Also, I killed all the halscope and started over. I think Todd's got the explanation.
Sorry for not responding to these earlier, I thought I had subscribed, but I wasn't getting notifications of your replies.
