Maschine only works in the Stepconf Wizard
09 Apr 2025 08:41 #325974 by Jan
Hello, I can control my X, Y and Z axes in the Stepconf Wizzard without any problems, but as soon as I start the normal program I can only move the X axis, the Y and Z axes can no longer be controlled.
09 Apr 2025 15:48 #325994 by andypugh
Replied by andypugh on topic Maschine only works in the Stepconf Wizard
This is often due to the stepper driver "enable" pins being wired, but not properly conttrolled.
The stepconf wizard doesn't dribe the "enable" pins, and most stepper drivers have an enable that is "enabled" when unconnected.
I would generally suggest saving pins and not wiring the enables. There is no real need for an enable control on a stepper driver (they can't run away in a fault condition, unlike a servo)
Time to create page: 0.304 seconds
