MPG error
- MiRu
12 Apr 2025 17:21 #326179
by MiRu
MPG error was created by MiRu
Sometimes two axes with MPG are switched on. Where should I look for the error?
- Thank you received: 5330
12 Apr 2025 17:24 #326180
Replied by PCW on topic MPG error
You would probably need to post your hal/ini files for anyone to determine the cause.
- MiRu
15 Apr 2025 14:14 - 15 Apr 2025 14:16 #326375
by MiRu
My files
Replied by MiRu on topic MPG error
Attachment not found
Last edit: 15 Apr 2025 14:16 by MiRu.
15 Apr 2025 19:19 #326400
Since these pins determine which axis jog, I would monitor them with Halshow
to see if maybe there is a electrical/switch issue with these signals.
parport.1.pin-04-in-not
parport.1.pin-05-in-not
parport.1.pin-06-in-not
parport.1.pin-07-in-not
The following user(s) said Thank You: MiRu
Time to create page: 0.096 seconds
