Custom interface board questions
- ajar171
16 Apr 2025 07:55 - 16 Apr 2025 08:41 #326432
by ajar171
Custom interface board questions was created by ajar171
Hi everyone!
Long time lurker here
Being fed up with the random avaiability of Mesa hardware in the EU, I decided to start designing an open source interface board. The schematics and PCB designs are almost finished, the firmware works so far, that I have communication between a development board and LinuxCNC and can control digital and analog inputs and outputs, read encoder inputs, etc.. So far so good...
Now to my questions:
- encoder scaling: where is it applied with a Mesa board? In the FPGA (did not find anything in the VHDL) or the hostmot2 driver or in LinuxCNC main software?
- motor acceleration and max speed: the same question
Thanks in advance!
Thanks in advance!
Last edit: 16 Apr 2025 08:41 by ajar171.
- Thank you received: 7488
16 Apr 2025 09:02 #326434
Replied by tommylight on topic Custom interface board questions
In LinuxCNC, in the ini file.Now to my questions:
- meister
- Thank you received: 502
16 Apr 2025 09:10 #326436
by meister
Replied by meister on topic Custom interface board questions
why something new again ?
there are now enough projects, why not bundle the work?
RIO calculate the offset and scaling inside the hal_component
and this inside LinuxCNC and the PID controller
- ajar171
16 Apr 2025 09:28 - 16 Apr 2025 09:35 #326439
by ajar171
Replied by ajar171 on topic Custom interface board questions
Thanks for the answers!
Why new? I use ethercat a lot at work, so I also wanted ethercat on my machines
Yes, a lot of hardware (stepper, servo drives, etc.) have ethercat and I also use them, but an encoder input from Beckhoff costs a fortune even on the second hand market. Also the ethercat driver in LinuxCNC works very nicely, and is in my opinion easier to configure than a Mesa card.
The I/O board is only a side project to be honest, my main goal is an open source ethercat MPG pendant with a display.
Last edit: 16 Apr 2025 09:35 by ajar171.
16 Apr 2025 09:34 #326440
That is from reading here, i have no EtherCAT experience, yet, so i can not deny nor confirm that.
But i can configure Mesa while sleeping...
So far you are the only one who thinks so!Also the ethercat driver in LinuxCNC works very nicely, and is in my opinion easier to configure than a Mesa card.
- ajar171
16 Apr 2025 09:43 - 16 Apr 2025 09:46 #326441
by ajar171
With EtherCAT, after You made your XML file, there is no real difference between Mesa or EtherCAT to be honest.
I got a Beckhoff coupler with 10 natively supported modules running in LinuxCNC in about 5 Minutes. For my custom board it was about 10 Minutes.
The only real additional work is making the XML file.
I also like the Mesa boards, but the boards I need are never on stock, when I need them (of course alway on stock, when I don't want to buy one).
I think the huge advantage of EtherCAT are the cheap (chinese) AC-servo and stepper drives and the really simple wiring. Advanced diagnostics are also simple with the TwinCAT software, but that sadly requires a Windows PC and a supported NIC.
The main reason designing a pendant is, that I have seen a nice one with a display for Mach3, and I really got envios
Last edit: 16 Apr 2025 09:46 by ajar171.
- unknown
- Thank you received: 323
16 Apr 2025 09:47 #326442
by unknown
Replied by unknown on topic Custom interface board questions
hostmot2 is open source.
I've put to together a couple of open source boards that work with a dev board, so far I've only had some interest from some guy on github.
There's nothing special on the FPGA side that is different from a Spartan6 dev board, SPI & EPP are easy to do. Ethernet is a little bit more difficult, but it is doable, I'm just having issues with using Mesaflash writing bitfiles.
- meister
16 Apr 2025 09:48 #326443
by meister
Ok, sorry, did not know that it is about ethercat.
building new boards for this is of course a good thing, i thought there would be another ESP32/Arduino board or something.
- ajar171
16 Apr 2025 10:20 - 16 Apr 2025 10:22 #326445
by ajar171
If I understand the source of the hostmot2 driver correctly, it is limiting the acceleration and also the driver does the encoder scaling.
This will make the firmware a bit more complicated, but I really want to use the original EtherCAT source already in LinuxCNC, and not develop a driver. This HW should be plug-and-play
Last edit: 16 Apr 2025 10:22 by ajar171.
- Thank you received: 4150
19 Apr 2025 20:38 #326733
Replied by rodw on topic Custom interface board questions
You won't need to develop a driver, you just need to write an xml file.
the wiring is substantially reduced using Ethercat drives over mesa.
Do you really need an encoder? The only purpose I can see is rigid tapping but thread milling is more efficient and it does not require it.
Everything about Ethercat is more expensive but it is the emerging standard. It does add a bit of complexity to the config. The bit that is not really worked out is the internal drive homing but using Linuxcnc homing is just as simple as mesa. I've had good luck finding reasonably priced Beckhof modules on ebay (including encoders) but some are outrageously priced, more expensive than new modules.
Ethercat with rs485 controlled VFD is the simplest way to run your spindle but there is now a linuxcnc driver for Omron mx2 VFD's .
Time to create page: 0.195 seconds
