Proxxon CU4
- Didi
21 Apr 2025 07:42 #326793
by Didi
Proxxon CU4 was created by Didi
I'm a newbie on this forum.
Is LinuxCNC compatible with the Proxxon CU4 interface (via parallel port or otherwise)?
- unknown
- Thank you received: 323
21 Apr 2025 08:07 #326794
by unknown
Replied by unknown on topic Proxxon CU4
USB isn't an option.
Parallel port maybe, but you would have to get Proxxon to confirm.
- Thank you received: 5330
21 Apr 2025 13:59 #326811
Replied by PCW on topic Proxxon CU4
Its parallel port compatible (uses the common "Mach 5 Axis BOB" inside)
So would work with a parallel port or Ethernet/SPI/GPIO/etc device that has a
parallel port like interface.
- Didi
21 Apr 2025 14:33 - 21 Apr 2025 14:39 #326814
by Didi
Replied by Didi on topic Proxxon CU4
In my opinion they are using the "Leadshine DM542EU" stepper motor controllers, but I couldn't identify the BOB. So, thank you for that info.
Last edit: 21 Apr 2025 14:39 by Didi.
