spindle speed mode to c-axis mode (cnc-lathe)
25 Apr 2025 02:01 #327022 by fery15sty
I tried using two modes on the lathe spindle.
I want to be able to change the spindle speed mode to c-axis mode which can be changed by entering Mcode
Here is an example of my code:
net caxis-cc-step <= stepgen.2.up
net caxis-ccw-step <= stepgen.2.down
net mode-caxis => and2.10.in0 => and2.11.in0
net caxis-cc-step => and2.10.in1
net caxis-ccw-step => and2.11.in1
net caxis-cc-out and2.10.out => or2.6.in0
net caxis-ccw-out and2.11.out => or2.7.in0
net spindle-cw-step <= stepgen.4.up
net spindle-ccw-step <= stepgen.4.down
net mode-spindle => and2.12.in0 => and2.13.in0
net spindle-cw-step => and2.12.in1
net spindle-ccw-step => and2.13.in1
net sp-cc-out and2.12.out => or2.6.in1
net sp-ccw-out and2.13.out => or2.7.in1
net servo-cc or2.6.out => parport.0.pin-08-out
net servo-ccw or2.7.out => parport.0.pin-09-out
M198 code:
#!/bin/bash
halcmd sets mode-caxis True
halcmd sets mode-spindle False
exit 0
M199 code:
#!/bin/bash
halcmd sets mode-caxis False
halcmd sets mode-spindle True
exit 0
I have tried all the codes above. M-code works well, it can change the spindle mode to c-axis or c-axis to spindle mode. but the resulting signal is not perfect.
I assume that the stepgen signal cannot use and2 or or2 logic, so that the stepping signal is damaged?
25 Apr 2025 02:46 #327023 by PCW
I would think Logic should be possible with stepgen signals if
you addf the logic components to the base thread instead of the servo thread.
The following user(s) said Thank You: fery15sty
25 Apr 2025 03:46 #327024 by fery15sty
Replied by fery15sty on topic spindle speed mode to c-axis mode (cnc-lathe)
exactly right. all my logic changed to base-thread.. and the spindle rotation works as expected. spindle speed mode or c-axis mode.
thank you PCW
best regards
