Magnetic scales on new gantry mill
- jackdavies
- Thank you received: 4
27 Apr 2025 13:18 - 27 Apr 2025 13:19 #327149
by jackdavies
Magnetic scales on new gantry mill was created by jackdavies
Hi all,
I am designing a new machine and would like to use Ditron magnetic scales on X & Y.
- The Y axis has dual motors, should I use a scale on each side or just one?
- Any recommendations of mesa boards to use here? 7i95T + 7i84U or 7i96 + 7i85
- Whats the process for setting this up in LCNC?
- I don’t believe these scales are differential signal, should I look for that?
Many thanks for your help!
Last edit: 27 Apr 2025 13:19 by jackdavies.
- Thank you received: 7488
27 Apr 2025 14:09 #327161
2. For step/dir drives, 7i95T should be enough if you do not need a lot of IO. So a 7i84 would be required on both combos if you do need more IO.
3. a bit of editing will be needed either way, plenty of info and help here once you get to that point
4. differential are better for noise immunity, but Mesa works with both differential and single ended. They should be incremental TTL, as far as i know. Absolute type would require other boards/config/ depending on type of comms.
Replied by tommylight on topic Magnetic scales on new gantry mill
1. You should, the expense does not justify having missed steps on one side and ending up with a miss aligned gantryThe Y axis has dual motors, should I use a scale on each side or just one?
The following user(s) said Thank You: jackdavies
- Henk
- Thank you received: 92
27 Apr 2025 14:59 #327166
by Henk
Replied by Henk on topic Magnetic scales on new gantry mill
I use Ditron magnetic scales all the time. Installed my first ones in 2019 on my 5 axis machine. Since the I have used installed about 20 of them. Not a single failure yet.
Be sure to specify that you want 1um resolution. Reader head model DMR2000. And also specify that you want the index pulse version (z signal) otherwise you get only A and B.
Yes. They are differential output
Henk
Henk
The following user(s) said Thank You: tommylight, jackdavies
- Hakan
- Thank you received: 454
27 Apr 2025 21:56 #327195
by Hakan
Replied by Hakan on topic Magnetic scales on new gantry mill
What's the difference to linear scales with glass scales?
- jackdavies
09 May 2025 12:08 #328062
by jackdavies
Replied by jackdavies on topic Magnetic scales on new gantry mill
Thanks Henk,
super useful!
Is the index Z pulse that you mention the R/-R signal on this table?
www.ditron-dro.com/product/ditron-high-p...g-machine-dro-tools/
super useful!
- zajc3w
15 Jun 2025 16:21 #330316
by zajc3w
Replied by zajc3w on topic Magnetic scales on new gantry mill
Megnetic are cheaper but more dust tolerant, just like rotary encoders.
Pros are price and dust/ contamimation tolerance, unless you get them full of steel shavings they will work.
Optical, glass scales will fail sooner than magnetic if you install them within fine dust presence area.
Big con is magnetic field sensitivity. Use of magnetic holders for coolant/air nozzles may shift your readings.
My(£100 motor and driver) magnetic encoder servo motors suffer so bad(plastic encoder covers) can make them rotate 3°(0.1mm axis move witn 10mm pitch screws) by putting magnetic indicator base next to them. Running spindle makes z motor 120mm away move the axis up/down 0.02-0.05mm and with right spindle speed it would start oscillating into oercurrent error. swapped the motor to optical encoder(£40 extra) and it all went away...
The following user(s) said Thank You: Hakan
Time to create page: 0.266 seconds
