Lathe - Virtual Compound Slide
- yngndrw
27 Apr 2025 16:30 #327170
by yngndrw
Lathe - Virtual Compound Slide was created by yngndrw
Hello,
I was wondering if it's possible in LinuxCNC to make a virtual compound slide on a lathe?
I'm considering options for a CNC lathe update and I'm thinking about adding a full set of manual controls. (With the screen acting as a DRO)
One such control would be an MPG to change the angle of a virtual compound slide, and another MPG to move that virtual compound slide - allowing tapers to be cut manually.
- Thank you received: 2176
27 Apr 2025 17:00 #327173
Replied by Aciera on topic Lathe - Virtual Compound Slide
- yngndrw
27 Apr 2025 22:24 #327196
by yngndrw
Replied by yngndrw on topic Lathe - Virtual Compound Slide
Thank you very much, that looks like just what I need! Now that I know the name of the component, I've been able to find other threads on it as well.
Time to create page: 0.283 seconds
