Can I home X and Y axes simultaneously?
  • Aciera
  • Aciera's Avatar Topic Author
  • Administrator
  • Administrator
30 Apr 2025 15:18 #327355 by Aciera
please post your ini file.
30 Apr 2025 15:20 #327356 by tommylight
Replied by tommylight on topic Can I home X and Y axes simultaneously?
Yes, set the same home sequence for both in the ini file.
30 Apr 2025 16:21 #327363 by tommylight
From the "machine" menu, choose "homing" then the axis you want to home.
30 Apr 2025 21:18 #327387 by tommylight
What problem?
None of the above are problems, you can set homing pretty much as you like or need or see fit.
01 May 2025 08:23 #327408 by pippin88
Replied by pippin88 on topic Can I home X and Y axes simultaneously?
Post your ini file
02 May 2025 22:27 #327566 by rodw
Replied by rodw on topic Can I home X and Y axes simultaneously?
In the ini file the HOME_SEQUENCE determines the home order on a home all. If two axes have the same sequence, they will home together. The exception is joint axes on a gantry which must home seperately.
Time to create page: 0.107 seconds
