Beginner Building a CNC - Questions About EtherCAT with Delta A2 and In
05 May 2025 18:46 #327774 by PCW
For basic step/dir servos, a 7I76EU should do (by itself)
The 7I76EU has:
5 axis of step/dir outputs
32 digital inputs (5 to 24V)
16 digital outputs (5 to 24V)
Isolated analog 0..10V output for VFD spindle speed control
encoder input for spindle synchronized motion
2 parallel expansion ports (for additional step/dir or encoder channels)
1 serial expansion port (for more digital I/O
The following user(s) said Thank You: Farzad
07 May 2025 06:02 #327925 by Farzad
Hi, thank you for your help.
I believe I’ve found the ideal combination: using a Mesa 7i95T together with a 7i85
7i95t for 6 axis xyzca and in future spindle servo and 7i85 for toll changer
If I’m mistaken or missing something, I’d appreciate your corrections.
07 May 2025 17:26 #327953 by Farzad
one more thing
Do we have input shaping in Linux CNC as Klipper in 3d printers ??
07 May 2025 20:04 #327957 by tommylight
No, not yet, nor am i aware of anyone working on it.
13 May 2025 13:10 #328376 by Z3rni3
Hey,
This might be something you already know or don’t need at all, but I learned way too late that there's a plugin called Mesact that really helps when configuring the 7i95T. The standard pncconf wizard doesn't properly support the 7i95T, so Mesact can save you a lot of time and hassle.
13 May 2025 19:31 #328412 by zmrdko
here is some inspiration for 7i95t config:
github.com/zmrdko/mesa_7i95t_config
The following user(s) said Thank You: Z3rni3
22 May 2025 10:59 #328904 by Farzad
Hello everyone
After talking to the Mesa electronic support team ( they are awesome), I placed my order for two boards
mesa7i95t
mesa7i85s
The arrival would take at least 60 days !!!
Currently, I am just waiting
Time to create page: 0.098 seconds
