LinuxCNC download for Debian 12
- Revinvoss
07 May 2025 01:29 #327919
by Revinvoss
LinuxCNC download for Debian 12 was created by Revinvoss
Hello to all, I am new here and, do hope to learn what I can for what I intend to do with the CNC Router table and, linuxCNC. found this forum by chance, luck me.
I have Debian 12 on a laptop computer, I will be using this for the CNC router table in the workshop, I hope!
The issue I have is that I can not find a good site that has LinuxCNC that works on Debian 12 for download.
Is there anywhere that has this as a download? I simply need to put it on a flash drive and install it to the laptop.
Any help would be appreciated.
- Thank you received: 7488
07 May 2025 01:33 - 07 May 2025 01:34 #327920
Replied by tommylight on topic LinuxCNC download for Debian 12
www.linuxcnc.org/iso/linuxcnc_2.9.4-amd64.hybrid.iso
Debian 12 with LinuxCNC included.
You can also install on Debian 12 just by running this in a terminal:This will install everything required to run machines, but beware that laptops are usually not good for that due to inherent power saving options.
Do give it a try.
sudo apt update
sudo apt install linuxcnc-uspaceDo give it a try.
Last edit: 07 May 2025 01:34 by tommylight.
- Revinvoss
08 May 2025 01:41 #327974
by Revinvoss
Replied by Revinvoss on topic LinuxCNC download for Debian 12
Thanks I will follow this info.
