Machine On Timer
07 May 2025 07:09 #327926 by babinda01
Machine On Timer was created by babinda01
Hi
I have a small but little annoying problem that I am hoping someone can point me in the right direction to.
I am running the Axis UI, and when I click the estop button and then the machine on button, my servo drives are initialized and then enabled.  My problem is that it takes approx. 10sec for my servos to startup, if I try and jog or home before my servos start the dros click over but no motion is done.  Is there a way I can put a timer in the system that won't allow any motion for that initial 10sec or so after the machine on button is pressed?
Regards
Andrew
10 May 2025 01:15 #328116 by tommylight
Replied by tommylight on topic Machine On Timer
Press the machine on button 10 seconds before releasing E-stop.
Does not work, nothing will work while e-stop is active.
See timedelay:
linuxcnc.org/docs/2.9/html/man/man9/timedelay.9.html
10 May 2025 02:14 #328118 by babinda01
Replied by babinda01 on topic Machine On Timer
Thanks Tommy
I think this is exactly what I was looking for.
Time to create page: 0.075 seconds
