Can I have 2 seperate interfaces on the same computer?
- Catch22
- Thank you received: 17
08 May 2025 14:33 #327993
by Catch22
Can I have 2 seperate interfaces on the same computer? was created by Catch22
Hello Everyone,
I have a question about using 2 interfaces on the same computer.
Right now I have my milling machine and it works on is axis 2.8.2 running on linux mint 19.3
But I really want to try Probe Basic but I don't want to ruin whats already working, can I
Install the latest version of Linuxcnc and Probe Basic and go back and forth between the two
to see if I can get it working on Probe Basic without deleting axis 2.8.2?
Thanks Mike
Thanks Mike
- Catch22
08 May 2025 15:30 #328002
by Catch22
Replied by Catch22 on topic Can I have 2 seperate interfaces on the same computer?
Any suggestions on how to do this?
- Catch22
08 May 2025 15:39 #328007
by Catch22
Ok so by installing Linuxcnc 2.9 and probe basic it won't change any of the original Linuxcnc 2.8 and axis stuff I have?
- Thank you received: 5330
08 May 2025 16:42 #328014
Replied by PCW on topic Can I have 2 seperate interfaces on the same computer?
2.9 will overwrite your 2.8.x installation
If you want to run both, its actually rather difficult because of the different Python versions
required by 2.8.x and 2.9.x
In general its possible to run multiple LinuxCNC versions (say 2.9.4 and 2.10) by having
a normal installed version and a RIP (Run In Place) version but 2.8.x and 2.9.x don't get along.
The following user(s) said Thank You: Catch22
- Catch22
09 May 2025 14:12 #328072
by Catch22
I need 2.9 because I want Probe Basic, and it won't run on 2.8 for me..
09 May 2025 14:53 #328077
To retain your old system, it might be simplest to install the 2.9.4 ISO
on a different PC (or SSD)
Time to create page: 0.168 seconds
