Ethercat LinuxCNC board for a 4 axis router
1 year 5 months ago #328190 by Hakan
The device linked to from aliexpress should work, it is a simple interface that is easily configured with the generic device.
But be prepared to learn the translate tool in your browser, documentation is all in chines.
Here is a translated screen shot from the manual
If you understand what this is, go right ahead. If you don't understand it, take a safer and easier path.
1 year 5 months ago #328215 by rodw
You could use this module instead www.aliexpress.com/item/1005004921994099.html
Then you could borrow my existing config for it
github.com/rodw-au/linuxcnc-cia402/blob/...t-conf-diewu.xml#L86
1 year 5 months ago #328482 by aeth
Thank you so much! This is hugely helpful! The only remaining issue is my Delta MS300 VFD that is currently controlled over 0-10V analog voltage, but I saw it's not too difficult to also set it up with RS485. If someone knows how to do this with LinuxCNC or knows some tutorials, I'd be super thankful.
Time to create page: 0.354 seconds
