- LinuxCNC
- General LinuxCNC Questions
- Best practice for installing custom Python packages in LinuxCNC?
- workshop54
- Thank you received: 9
14 May 2025 13:54 - 14 May 2025 13:56 #328446
by workshop54
Hi all,
I’ve developed a custom Python package — and not just a loose .py file, but a real multi-module package, complete with pyproject.toml, unit tests, internal structure, and even a __str__ for logging prettiness. Yes, I know, it’s total overkill for something that just drives the lubrication pump… but hey, it’s fun
The code I wrote can be found here if anyone is interested: github.com/johanvergeer/maho-mh400e-conf...ree/main/lubrication
Now I want to use this package from a Python script that’s launched via loadusr in my machine config.
Some context:
Any advice or patterns you use would be greatly appreciated!
Cheers,
Johan
Best practice for installing custom Python packages in LinuxCNC? was created by workshop54
Hi all,
Some context:
- The script uses linuxcnc, hal, and qtvcp modules.
- LinuxCNC runs on the global system Python interpreter as far as I can see, which means my package has to be available outside of any virtual environment.
- Installing with pip install . into the global Python environment technically works, but it’s strongly discouraged on modern Debian-based systems due to PEP 668. I’ve already seen Poetry try to uninstall half of /usr/lib/python3
- Virtualenvs don’t help much either, since they can’t see LinuxCNC’s compiled modules.
- Adding my repo folder to sys.path is possible, but feels like duct tape.
- Is it acceptable to install your own packages into something like /usr/lib/python3/dist-packages/?
- Is there an officially recommended way to include custom Python packages that need to be imported across multiple files or used in different HAL components?
Cheers,
Johan
Last edit: 14 May 2025 13:56 by workshop54.
- workshop54
14 May 2025 14:34 #328459
by workshop54
Replied by workshop54 on topic Best practice for installing custom Python packages in LinuxCNC?
Fully agreed — if LinuxCNC ever gets a proper Java API, I’ll gladly throw my Python into the chip tray
Until then, I’ll just keep pretending my Python package has structure and discipline… while knowing deep down it’s all held together by logging statements and good intentions
- Thank you received: 7488
14 May 2025 14:47 #328463
Replied by tommylight on topic Best practice for installing custom Python packages in LinuxCNC?
If you want to move away from Python, try "Ruby on Rails".
Going from Python to Java is absolutely moving backwards.
- JT
- Thank you received: 593
15 May 2025 11:31 #328504
by JT
Replied by JT on topic Best practice for installing custom Python packages in LinuxCNC?
Why not just build a deb and install your package?
github.com/jethornton/simple-deb
github.com/jethornton/simple-pyqt5-deb
Or if you're using Flex GUI you can just add it to your ini and it gets imported.
gnipsel.com/linuxcnc/flexgui/python.html
JT
JT
- Thank you received: 4150
19 May 2025 12:38 #328740
www.reddit.com/r/pythontips/comments/122...s_switch_statements/
Personally I much prefer python over php and Java but C I am much more comfortable with.
It just annoys me that Python can do things in 100 lines that would take 1000 in C
Replied by rodw on topic Best practice for installing custom Python packages in LinuxCNC?
It does now since 3.10Python does not even have switch statements!
24 May 2025 10:15 #329040
Its really about progrmming defensively so you can enjoy the journey.Coding is not about speed, it's about the journey.
24 May 2025 13:09 #329044
You can have both, try Assembly !
- LinuxCNC
Time to create page: 0.252 seconds
