Retrofit SODICK A320D
22 May 2025 11:35 #328907 by MARTCENT
Retrofit SODICK A320D was created by MARTCENT
Hello, good day. I'd like to know if anyone has been able to help replace the original computer on the Sodick A320D machine.
Thank you very much.
23 May 2025 13:48 #328982 by MARTCENT
Replied by MARTCENT on topic Retrofit SODICK A320D
Two PCs were used in those machines.
NEC 9801UF / NEC 9801UV11
Thank you
23 May 2025 20:25 #329014 by andypugh
Replied by andypugh on topic Retrofit SODICK A320D
Do you want to replace like-for-like or swap out for a LinuxCNC conversion?
24 May 2025 01:12 #329027 by MARTCENT
Hi, can it be run on Linux?
25 May 2025 15:35 #329110 by andypugh
Can _what_ be run on Linux?
Can you explain what you want to do?
Time to create page: 0.097 seconds
