parallel port
25 Nov 2010 21:18 #5618
by andradela
parallel port was created by andradela
HI, anybody knows if is possible to use two parallel ports with a emc2, one will be used to control step motors and another will be used as I/O by classic ladder?
26 Nov 2010 00:28 #5621
Replied by andypugh on topic Re:parallel port
Yes. EMC2 can handle as many parallel ports as your motherboard can cope with.
However, consider a Mesa 7i43 instead, which plugs into the parallel port and gives you 48 IO pins. It does step-generation and PWM etc on-board. Cost is around $80.
Some idea how to use it will be found here. www.linuxcnc.org/docview/html//drivers_hostmot2.html
- Mike_Eitel
- Thank you received: 185
26 Nov 2010 08:39 #5622
by Mike_Eitel
Replied by Mike_Eitel on topic Re:parallel port
Hi Andradela
Here some text snipes I copied in to a file that I hope to find it next time .
Error when starting EMC:
insmod: error inserting '/home/jepler/src/emc2/rtlib/hal_parport.ko': -1 Device or resource busy
If you encounter this problem, you must make sure that the Linux kernel module parport_pc is not loaded at boot time.
On Ubuntu systems, you can do this by creating a file in /etc/modprobe.d/ with the one line
install parport_pc /bin/true
The EMC2 packages put this line in the file /etc/modprobe.d/emc2.
EMC appears to start, but no signals ever appear on the parallel port (the motors don't turn).
Add the following command before the line loading hal_parport in your hal file.
loadrt probe_parport
The Linux parallel port driver must be completely disabled for EMC's hal_parport driver to load.
However, as we learned after the release of 2.0.1, this disabled certain parallel ports that are "PNP" (plug and play) devices.
The new probe_parport realtime module performs the probing for one type of PNP port.
Mike
Mike
Time to create page: 0.076 seconds
