Up grading Debian 12 rt
27 May 2025 15:52 #329231 by aaron
Up grading Debian 12 rt was created by aaron
Hi
File Name: Upgradeerror.txt
File Size:2 KB
I have a fresh install of Debian 12 and I want to make sure everything is up to date, but when do 'sudo apt upgrade I get the error in the attachment;I am not sure how to fix this. Help would be much appreciated.
Aaron
27 May 2025 16:12 #329235 by tommylight
Replied by tommylight on topic Up grading Debian 12 rt
In a terminal one line at a time
sudo apt update
sudo dpkg -P raspi-firmware
sudo apt dist-upgrade
27 May 2025 20:09 #329268 by aaron
Replied by aaron on topic Up grading Debian 12 rt
Thank you for this. That did the trick, but I have a couple of questions.
How am I running a raspberry pi all of a sudden?
And
Is it possible to install a nvidia graphics card and still use Linuxcnc?
Thanks again
Aaron
27 May 2025 20:50 #329273 by tommylight
You are not, it is a remnance of a Debian f@kup that is still dragging on.
Most probably not, proprietary NVIDIA drivers did not work at all on RT-Preempt kernel last i tried over a year ago.
You are welcomed, always.
The following user(s) said Thank You: aaron, rodw
Time to create page: 0.149 seconds
