Higher (more than 5V) step/dir voltages with mesa cards (7i96)
- juliankoenig87
- Thank you received: 55
27 May 2025 13:13 #329248
by juliankoenig87
Higher (more than 5V) step/dir voltages with mesa cards (7i96) was created by juliankoenig87
right now I try to connect a 7i96 with (very) old Berger Lahr D500 stepper drives. The drives have internal pullups (10k) to 12V at step and dir inputs.
So I need a solution to sink the drive inputs to ground while not killing the (I assume) hex inverters on the mesa card.
Is there a way to change the inverter on the card (7i96) with one tollerates up to 12V?
The drives are obviously single ended. So the "-" step/dir output of the card is enough.
Best regards
Julian
Best regards
Julian
- Thank you received: 5336
27 May 2025 13:53 #329256
Replied by PCW on topic Higher (more than 5V) step/dir voltages with mesa cards (7i96)
I would suggest using something like a ULN2003 as a level shifter
- juliankoenig87
27 May 2025 14:13 #329258
by juliankoenig87
Replied by juliankoenig87 on topic Higher (more than 5V) step/dir voltages with mesa cards (7i96)
Yes, you are right. Didnt thought about darlingtons, but yes, they will be fast enough for this configuration.
So I will have to build a small board in between.
27 May 2025 14:19 #329260
You can still get ULN2003's in DIP packages
so for three axis only one chip (perhaps in
a socket) on a bit of perfboard would do.
- juliankoenig87
27 May 2025 14:34 #329264
by juliankoenig87
Yes. I also think its the easies solution.
Darlington transistors at each driver is way more work.
Thanks for the hint. Will do it with an array.
Time to create page: 0.306 seconds
