Huanyang GT Series VFD Issues
- kubes
- Thank you received: 4
29 May 2025 04:24 #329347
by kubes
Huanyang GT Series VFD Issues was created by kubes
I am trying to get a Huanyang GT VFD to work with LinuxCNC. When I start Linux CNC or via halrun..
I can successfully connect and send commands via mbpoll and the command line
I've tried different baud rates, etc and the same results. Works via the command line, but not via the hal.
Any ideas?
halrun
loadusr -W hy_gt_vfd -d /dev/ttyUSB0 -p none -r 38400 -s 1 -t 1 -S1410 -F60 -f10twopass:pass0: loadusr -W hy_gt_vfd -d /dev/ttyUSB0 -p none -r 38400 -s 1 -t 1 -S1410 -F60 -f10
hy_gt_vfd: device='/dev/ttyUSB0', baud=38400, parity='N', bits=8, stopbits=1, address=1
read_modbus_register: error reading freq-fb (register 0x3000): Connection timed out
set_motor_off: error writing 5 to register 0x1000: Connection timed out
set_motor_off: error writing 5 to register 0x1000: Connection timed outI can successfully connect and send commands via mbpoll and the command line
$ mbpoll -m rtu -a 1 -0 -t 4:hex -v -r 0x1000 -b 38400 -P none /dev/ttyUSB0 0005
debug enabled
Set start reference=4096
Set rtu baudrate=38400
Set rtu parity=none
Set device=/dev/ttyUSB0
1 write data have been found
Set data=5
Word[0]=0x5
mbpoll 1.0-0 - FieldTalk(tm) Modbus(R) Master Simulator
Copyright © 2015-2019 Pascal JEAN, https://github.com/epsilonrt/mbpoll
This program comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it
under certain conditions; type 'mbpoll -w' for details.
Opening /dev/ttyUSB0 at 38400 bauds (N, 8, 1)
Set response timeout to 1 sec, 0 us
Protocol configuration: Modbus RTU
Slave configuration...: address = [1]
start reference = 4096, count = 1
Communication.........: /dev/ttyUSB0, 38400-8N1
t/o 1.00 s, poll rate 1000 ms
Data type.............: 16-bit register, output (holding) register table
[01][06][10][00][00][05][4D][09]
Waiting for a confirmation...
<01><06><10><00><00><05><4D><09>
Written 1 references.I've tried different baud rates, etc and the same results. Works via the command line, but not via the hal.
Any ideas?
- Thank you received: 5330
29 May 2025 18:09 #329379
Replied by PCW on topic Huanyang GT Series VFD Issues
Latency is not really an issue with Modbus as it's not real time to begin with...
- kubes
29 May 2025 20:09 - 30 May 2025 00:11 #329384
by kubes
Replied by kubes on topic Huanyang GT Series VFD Issues
I am 100% convinced it's a software issue. I was able to create a basic application using the Modbus library, using the same basic logic as the hy_gt_vfd hal driver, and it works. Meaning no communication error, and I can start and stop the spindle fine. So that along with the mbpoll that also works, it's in the hy_gt_vhf hal module.
I think that there is a memory allocation that stepping over the modbus context (where the port settings are)?
Last edit: 30 May 2025 00:11 by kubes.
- kubes
01 Jun 2025 04:16 #329492
by kubes
Confirmed is a SW issue.
I replaced the hy_gt_vfd driver with mb2hal, which is a generic modbus HAL component, no HW changes, and it works.
- Hakan
- Thank you received: 454
01 Jun 2025 05:55 - 01 Jun 2025 05:56 #329494
by Hakan
Replied by Hakan on topic Huanyang GT Series VFD Issues
If standard Modbus works one can wonder why there is a hal componenet for this vfd?
The old Huanyang vfds use something similar to but not quite Modbus so there it is needed.
Last edit: 01 Jun 2025 05:56 by Hakan.
Time to create page: 0.253 seconds
